Configure the static MAC address parameters.
Configure a static MAC address of a VLAN:
Switch(config)# vlan mac-address-static 1 0x00:0x00:0x00:0x00:0x00:0x01 1/1
Use the data in the following table to use the vlan mac-address-static command.
Variable |
Value |
<1-4059> |
<0x00:0x00:0x00:0x00:0x00:0x00> |
Indicates the MAC address. |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
